"Low Wash" warning light
rikguy33
Altoona, PA
When I start my Jeep I have a "low wash" warning light and chime go off a couple of times and the "low wash" warning continues to flash over the mileage. The washer fluid is full. Does anyone know where this sensor is so that I can see if it's even attached or needs to be replaced?
Thanks.
The washer tank sensor is in the the washer tank.If you have a '02-'04 KJ then you can get access to it through the passenger front wheel well,the litte trap door to replace the foglamp bulb,for the '05+ I couldn't tell you.It'll be the only other plug on the tank besides the washer pump,it is just held in with a rubber grommet.
rikguy33
Altoona, PA
The plug is connected so the sensor must be bad. I'm going to unplug it and see if it still shows the warning light or not.
