Looking for some opinions - radiator
hellomattwhite
Happy Friday everyone!
I've got to replace the radiator on my 05, has the common hairline crack at the top on the drivers side. I've read through a bunch of threads here and learned the differences between the 02 rad with the trans cooler inside and the subsequent version utilizing the exterior cooler.
I live in NC and we get pretty hot summers and my Lib will see a fair amount of time in the hills (bought it in September so it hasn't seen summer with me yet). I don't plan to use it to pull anything, maybe just the occasional trailer rental around town. Anyhow, I figured if it needs replacing I may as well get the early 02 rad and pair it with the exterior cooler for peace of mind and a happy transmission. BUT, in looking around, I've also learned that Mopar has discontinued production of that early version. I've seen tons of after market rads with the interior cooler, but I don't really want to go down that road.
Long story short, I found a used one off an 02 from a part yard for $75 shipped, and that includes a 90 day window to receive a refund if it leaks. Donor vehicle had 152k on the clock. OR, I just shut up and get a new Mopar rad without the interior cooler and call it a day. My rig has 123k on the clock with a cracked radiator, so that one with 30k more miles is just as likely to crack ... ?
What would y'all do?
IMO, I would go new, cheaper in the long run
That is unless you like to gamble , then go used , ....................
and as always HOAT coolant and I would do Mopar thermostat and new hoses then you are done and know everything is good in cooling system
hellomattwhite
Don't tend toward the gambling life myself. Going new is the more logical route, but I also like going down the rabbit hole of endlessly making things "better". Appreciate your input Tom!
Get an aluminum one then
several swear by them
I know about going down rabbit holes , been going down a lot of them building 4x4s over the last almost 50 years
OldJoe
Gurnee, IL
Just replaced mine, '04 sport. 5 speed stick. Got mine from Rock. Rather involved. Had to take most of the front end off. A friend could come in handy.
