Lift recommendation
kg4kpg
Charleston, SC
Howdy y'all. My name is Chris and for the next year I'll be using and modifying my daughters Liberty while she enjoys a year-long vacation in Baghdad. it is an '04 2 wheel drive but due to the snow and ice they can get at her home base (Ft. Riley, KS) I want to put on a little lift and some good tires. Looking to go with 2" that doesn't require any cutting or major alterations and probably 30" all-terrains, brand not yet decided. I'll do the install. I am a jeeper myself, drive a lifted '05 LJ. If all goes well with hers I may just pick up a KJ to build up later for me after my next overseas tour.
Anyway, budget is not a major issue but would like to stay around $500 or less if posible.
Here is one I was considering:
http://www.4wd.com/productdetails.aspx?jeep-sid=357&plID=60&partID=7001
I liked this one as well but a bit pricier:
http://www.4wd.com/productdetails.aspx?jeep-sid=357&plID=70&partID=42831
Thanks for your time,
Chris
(welcome)
I'd recommend an OME/ Bilstein lift, it will cost about $700, but it will last longer, and ride tons better than stock.
See the Lift FAQ in this section for the part numbers...
