liberty starts then shuts right off
mikeavery
usa
Ok so my 2003 jeep liberty will run fine for a couple seconds and shut right off. This happened right after trying to install a dball module. I connected to pin 2 on the obd port. Pin 10 on connector c2 on the 42 pin connector of the junction box, pin 9 on the gray 22 pin connector at bcm, and pin 4 on the 26 pin connector at bcm. Any input would be awesome. I disconnected everything o installed and checked all fuses with no luck. Thanks
mikeavery
usa
I was finally able to get a code out of it, p1686 so your right on the money. Only thing is the jeep has black keys so there is no chip. Maybe I activated the skim by accident? Also now there is a key symbol flashing on the dash that has never illuminated before. Think I might have to take it to the dealer to shut down the skim.
