Liberty coil springs
no fear
South Africa
Hi All
Does anyone know if a Grand Cherokee ZJ rear coil springs will fit on a 2005 Liberty 3.7
I have a set lying around and was hoping it will fit and give a little bit of a lift.
4x4kayak2112
tx
Stick them in and see.....its not thay hard
Sent from my Home Phone using Tapatalk
Check the diameter of them but I think they are smaller around
Plus the length would be off just better to get the right ones for a KJ
Kind of like using a tack hammer to put horseshoes on, may work but the old mare will be upset by the time you're done
no fear
South Africa
Thanks for advice. I’m from South Africa so lifts are scarce and very expensive here.
Will try and fit them and post the results good or bad.
