leak ? pics
krisP
NY/PA
is this coolant ? white residue , i cant find any apparent leaks
could be.
Any white residue around the radiator/WP/lower rad hose/heater hoses?
might want to pressure test your system.
krisP
NY/PA
could be.
the pics are the only places with that residue, no loss in coolant level. Ill dig out the pressure tester from the garage
dude1116
Pompton Plains, NJ
If I had to guess it might be your WP spraying if it's getting on the side of the air box as well as the fuse box.
krisP
NY/PA
some possible residue around the WP , no real sign of apparent leak hmmm maybe ill replace it , i think its original anyways
krisP
NY/PA
Is it dusty at all? Could be a belt edge fraying.
no not dusty , belt is only a few months old also. Im just stumped at where the leak is. Also need to find my pressure tester to confirm leak
krisP
NY/PA
hmmm interesting, ill have to check it. Seems to only accumulate on longer drives, an hour or over
teeje
Toledo
Definitely something belt driven. You can see the pattern of it how it was "flung" if you will
Sent from my SM-N930P using Tapatalk
krisP
NY/PA
yep , pretty sure the WP leaking from the bearing area... easy to replace and will probably need soon anyway. Thanks everyone
Jbergun
Chicago
it is coolant no doubt. I had the exact same thing. My wp was weeping and the top corner of the radiator cracked. I had that same spray pattern on the intake box and because of the mech fan it was on the hood liner too. Coolant dries white so its easier to see and diagnose.
krisP
NY/PA
alright thanks, i looked it over this morning and the radiator is fine but i ordered new gates WP and some hoat
krisP
NY/PA
also new thermostat while im in there. Hopefully it doesnt decide to fail on me between now and wed when the parts come in
