Key stuck in ignition (and the fix)
mprice62
Southern Ohio
I am having the same issue with my wife's new-to-us 2002 Liberty. I am going to try to install a spring that will assist the cable with that last 1/8" of travel.
mprice62
Southern Ohio
FIXED!!! And FOR LESS THAN $3.00!!!
So, I went to Lowes' and purchased a package of springs (Hillman#543311, 2 pack. Found in the same aisle as screws, and the specialty hardware drawers).
The spring is a 5/16" x 1-1/8"x .023" Extension Spring. It has a standard "U" shaped "hook" style end.
One end needs to be pinched together, so that the "U" is mashed together. Then, bend a right angle in that end, so that it will catch the brass "bead" on the actuator cable.
The other end needs to be bent, so that you straighten out the "U", and then reshape it into an "L", with a slight bend at the very end. This end goes through the clip on the "keeper" on the shifter cable (see photos).
The spring is strong enough to assist with the last 1/8" of travel in the actuator cable, but not so strong as to interfere with the functionality of the actuator, or the shift lever.
I hope this helps.
mtnclimber
Colorado Foothills
Your KJ must be an '05 as the shifter cable retainer was different on my '06 - it did not have the slits in the retainer to hook the spring to. I had to find a different spot to attach the spring on mine. Also the spring did not quite take care of the spring return on mine as I had to loosen the set screw on the shifter knob and readjust the knob/lever height to mine so the key could be removed when in park.
formerfatboys
Illinois
52109779AG
Is this the part that I need on an '06 Jeep Liberty? Anyone have any tips on where to look in the service manual to find the section on this?
I have the same issue and using a screwdriver as shown in the YouTube video a few posts back does indeed get the shifter to stop slipping into others, but my key broke off and doesn't seem to want to come out which is an added bonus.
iamjpad
USA
Oh wow. I did this fix on 02 Liberty using the spring from Lowes and just like that problem is fixed.
Just to test it out before the spring was attached. I could see that if the cable didn't return fully, the key would be stuck so the spring fixed it for sure.
Damotee
Cape York, Australia
I get this problem on my 05 Renegade. Applying the brake and pressing the button on the shifter fixes it. Annoying for sure.
smittyfromPA
PA
My sister just told me a few days ago her key was stuck in the ignition of her 2015 Renegade. So its not just a Liberty thing.
Hdrider
Catawissa Mo
Both of my 02s do this every now and then. If you lightly slap the shifter in park it solves the problem. Works on ours every time.
RENEGADE Concept
Michigan, U.S.A
I've been dealing with this problem for a year and a half now. Changing the shift interlock cable seemed to work for several months and then it started doing it again. I've gotten by with information listed here. But here's a new twist I recently figured out - the problem is heat sensitive! Go figure. It's winter where I live so of course I'm always driving with the heat on this time of year. If I'm not in the vehicle very long with the heat running there's not a problem getting the key out. But if I take a longer drive and the interior gets warm it with get stuck nearly all of the time. However once the vehicle sits outside and gets cold again I can go out and like magic I can instantly turn the key that extra to take it out!
krazyjar
Georgia
04 Liberty Renegade
My key gets stuck and after it has cooled down the key comes right out as well.
RENEGADE Concept
Michigan, U.S.A
Since it's still cold out I've taken to driving with the heat off as much as I can so I don't have a problem. But when summer comes I'm screwed, because running the AC doesn't get things cold enough to help. So back to the dealership I will go again. Grrr
DFW333
Dallas, TX
I just had this problem starting today. Glad to find out it appears to be an easy enough fix. As for the heat being an issue like in the last couple of posts, I've never had this issue before today and I'm in Texas. Had my 2006 Liberty since 2014, been through plenty of 105+ degree summers.
I'm surprised they don't issue a recall on this. The shifter being able to move without the brake or release button being pressed is incredibly dangerous. I get it's a different problem, but every video I see about the key not releasing also mentions the shifter issue as needing to be fixed at the same time.
DFW333
Dallas, TX
I just got mine out with no difficulty at all. Took the cover off the gear selector and found a little pin that moves when the gear selector release is pressed. I pulled it up with my index finger and the key released. Looks like my fix will be to reset the screw on the front of the lever. Now just have to find a15 Torx bit.
daves06lrenegade
Massillon, Ohio
I had this problem recently and I found by removing this cable at the steering lock assy (yellow push in connector)... I could remove the key...I could car less what position the shift lever is in when I remove the key...
Now if I could only find schematics for the dome light circuitry, door ajar switches, and the BCM... I have yet to locate the wiring diagrams within the Jeep Service manual... I have a dome light that will only go off with the stalk switch in the ON position... and never on when the doors are opened
Added 09/27/2018
Found a complete copy of the Jeep Liberty service manual with the schematics (area 8) and found that the wiring harness inside the swing gate was pinched by the door stop.. Now onto the transfer case wiring... Dave
kmitch
Noblesville, IN
stuck key
Hey this happened to me as well just a long list in the line of things this Liberty has wrong. However, before you take it in to get fixed or spend a dime try this....there is a set screw on the shift handle towards the front of the handle it's a tox screw.....loosen the set screw and gently pull up on shifter while holding it tighten the set screw....it's worth 5 min of you time!!!!!! if you need the cable it's an easy diy thing.
Worked like a charm for the moment. Can get key in and out no problem.
Transmission can be moved about without the normal stops. I'll deal with that separately.
AWolfCalledWander
Over the weekend, my Jeep had a problem. I had been making a couple trips around town to run some errands. I got back to my brother's house and shut off the Jeep. I started to get out when I realized that my key was stuck in the ignition. It would not turn back to the stop where you can get the key out. I try turning the key back and forth and also shifting the transmission(This is on a 2006 4X4 automatic BTW). No luck. The Jeep was in park, so we went in to see what we could find on the net. Not much, but we did see one comment about the Shift Interlock having problems. So back out I went and tried the key and the shifter a few more times. Still no difference. So I started pulling the console apart to see if anything was binding. What I found was that the shift interlock cable was not returning to it's proper position when in park. I could push it with my thumb and then it would release the key. I only had to move it about 1/8" to get it to work. I did this the rest of the day to get where I was going.
The next day I took the console completely apart to determine why the cable was not working as it should. What I found is that there is a small solenoid with a brass actuator bar that pushes the shift interlock cable into the correct positions depending on what gear you are in. This solenoid was not pushing the cable far enough forward to allow me to get the key out of the ignition. This solenoid has part numbers on it so I copied them down and went to the parts store. No luck, it must be a dealer only part. So on Monday I went to the dealer. I describe the part and give them the part numbers. What I found out next is that the fix is to replace the entire automatic shifter assembly and shift interlock cable. That is the only way Mopar sells these parts. I even took the shifter out of the box while there and pointed out the part I needed on it. The guy said they had done some revisions to the shifter and cable and that they only sold the whole assembly. He said this was not a recall item, but the revisions had been made and on his computer it noted to sell a new interlock cable with the shifter because they had been revised. I went ahead and bought the shifter assembly and cable, $120 total. I expected much worse.
I went home and started swapping parts. I could tell that the shifter assembly and cable did look slightly different in some areas. The interlock cable is also spring loaded and seemed much springier than my old cable. The cable alone may have fixed my problem, but I went ahead and replaced both. Total repair time was about 2 hours and that was with me taking it slow and making sure I was doing everything correctly. Also the process for doing this repair is documented fairly well in the Haynes Jeep Liberty 2001-2004 service manual and instructions match very well even on a 2006 model Jeep like I have. The main things to remember are, the console has to come completely out. And the bottom half of the cover around the steering column will need to come off. Tools needed for this job are; #2 Philips Screwdriver, A couple flat tip screwdrivers, Torx T15 driver, 10mm deepwell socket and ratchet, needlenose pliers, and a good bright droplight. The console removal was fairly easy, except for one screw that eluded me for a bit. If I had referred to the Haynes manual first, I would have found it more quickly. This screw was under the leather boot for the transfer case shifter. It also helps when removing the console to have the transmission in N, the transfer case in N or 4LO, and the parking brake pulled up.
Well hopefully this info will help somebody in the future.
Thank you for posting!
