Hi all, first time posting here.
My Mother-Inlaw has a 2007 liberty with 130k miles on it now. Its her DD and it does a lot of long hauls (4-6 hour drives) so it sees a lot of highway.
We just took it down to her moms house (6 hour drive) does great cruising at 80MPH on the interstate.
However i noticed when were were driving around town, when going around 30mph in 3rd gear (auto) with the TC Locked, and light throttle a shuttering feeling occurs, almost like a mis fire feeling, but it doesn't sound like a mis fire. I think its most noticeable when the engine power/speed is equal to the speed of the vehicle.
I am worried what it might be, The Transfer case, or alex bearing?
This vehicle has only had one trans fluid change and thats it besides the Oil changes.
IM going to get the stuff to change the diffs and trans case (i got the correct parts information from this forum).
Also i noticed the Power steering is starting to wine, and i think it might be because it has some normal power steering fluid mixed in the with the +4 because it was below the add line and we were going on a 6 hour drive (6months ago) so i plan to suck it out, and refill with the +4 and cycle the wheel back and forth, and repeat until i use a few quarts of +4. Hope it won't ruin the pump.
One more thing, during cold starts when its about 50 degrees, i hear a slight noise, almost sounds like a lifter, but it doesn't occur at the rate that would make me think its an actual lifter.
What would be a common thing to make this noise? Waterpump maybe?
Thanks for reading my rambling.
