Any opinions as to which way to go, the tent would be my first choice as to price.
Any pros and Cons to the jeep tent?
thanks
Hotel room.
Tents would leak if they weren't properly set up.
As far as cost goes... I borrowed it for free... But the owner bought it used for $500. I have seen a few other used ones go in the range of $250-500
Get a nice tent... This was where i stayed last weekend, nice big tent, only set me back $80, big enough for two queen sized beds, has a closet that pops out in the back, and its tall enough to stand and walk in. Since it was just me i set up my queen sized airbed on one end and the other end i had my cooler, a small table and chairs, fan, lantern, you name it. Went through a heavy downpour one night, so its been weather proven, two inches of rain in less than an hour, only one minor leak at the door flap which i have since fixed with some seam sealer.
I used to own a popup as well, 16ft unit with two queen sized beds, kitchenette, the whole nine yards. Was nice but too much for one person to use. I don't always have the whole family with so it just didnt make sense to have all that.
What would be the point?
we are talking about the one that connects to the back of the Jeep right?
I just dont see the point
I have 2 tents
1 is a standard "big" tent that sleeps like 8 people but you can stand up in it
made by Colman I think
The other is smaller 2 man tent for back packing
cost way to much but only weighs like 2# or something like that
we bought it years ago when me and my wife had time to go back packing
now I use it when I go off in the Jeep by my self over night
oh the pop up camper will have AC
that looks like the ozark trails tent that wally world sells. what tent is that?
Ummmm, A/C / Heat... kind of a big deal. How about a stove, running water, toilet/shower (if your nor cheap), Cleaner, storage...No brainer to me. I have been looking for one for a little bit. We have a big tent, can't use it down here unless the weather is just perfect.
My vote is obviously for the pop up.
After tent camping for many years as a kid we finally got a pop-up. I cant imagine going back to tent camping after camping in the pop-up. It doesnt have the toilet in it, which I wouldnt want in something that small anyway, but it does have a small DC/AC/propane fridge, small sink, a king bed and a queen bed. It also has propane heat, electric heat, and A/C. Makes camping much more enjoyable and easy. We keep everything we would normally take camping in the camper so short of getting food and hooking up the camper, were always ready to go camping. The thing weighs around 3,000lbs, my kj handles it pretty good but it cant get a little slow on the hills. Has electric brakes so stopping is no problem. Ive got OME HD springs and air bags but it still sits down a little in the back. The tongue weight is around 350lbs.
I posted a ad on craigslist for a cheap repairable or just old pop-up, and got one reply for an old Coleman. The owner has had it for about 15 years and hasn't moved in a few years and said its all mine for free, and hes got the title ready to sign over for me.
I know it will need tires right away, but bearings/hubs rims and tires will be replaced so I can change the bolt pattern to 5x4.5" and put some matching Icon wheels!
Just goes to show if your patience and willing to put some work into a camper then you can have a get one for cheap.
I should be getting it Wednesday and post some pics of it, once I know what I'm getting myself into.
Sounds like a deal! If you can, toss a couple new tires on and inspect the bearings before hauling it home, unless you have a VERY SHORT drive to get it home. Chances are the tires are shot after a few years, unless he had it on jackstands to keep the pressure off the tires and covered them to protect from UV damage. Get it moving and the heat starts to build in those tires and they will fail. The wheel bearings probably have water in them by now also, i've dealt with milky wheel bearing grease on utility trailers and small campers many times.
If nothing else at least buy a spare if it doesn't have a good one on it for the ride home. And if you can pull the grease caps off the wheels and tap in some bearing buddies and pump through about a half tube of grease on each hub while spinning the wheel. Sounds stupid but this is how i have gotten many a used trailer rolling until i could tear them apart and clean and repack or even replace the bearings. Since its an older Coleman, look on the back side of the hub for a grease zerk, some of them actually had one back then.
And if you need any info check out this forum...
http://www.popupportal.com/
Lots of good folks over there, been a member there for years. And post them pics so we can see your new find behind the KJ!
Thanks for the link, they got lots of good info over there. I actually am borrowing a buddies car trailer to put it on, just to be safe since its a 40 min drive home, all on a decently busy highway, and the last thing I need is a problem, so its better to be safe and not worry about tearing into it till I get home.![]()
