Jeep Liberty 2002 parting out and need gone
JoeyG23832
Richmond VA
Anybody need parts for an 02 liberty? I picked it up for a few parts i needed since it was cheap and wrecked. drive train is in good shape. lot of highway miles but starts and drive great. let me know if yall need something. thanks. my zip 23832 VA
Joey
FIRE74
St.Leonard, MD
I need the rear speed sensor/abs wire and connector that plugs into the the abs sensor on top of the rear diff, and also the engine fan relay (I can send a pic if needed) Thanks!
JasonJ
Michigan
front left (drivers door) latch/motor. The one that moves the lock rod up and down. Mine is all borked and makes grinding/squealing noises.
Also, the plastic kick panel that goes around the hood release lever.
mindbomb
California
Is it limited model? If so I want the leather seats ;)
drewwenmoth
Akron ohio
Does it have factory towing? I need the electric fan and shroud
HerronScott
Staunton, VA
If a Limited, I need the silver part that goes around the door lock on the rear driver side door. Also a rear cargo cover (needs to go with taupe interior).
Scott
Logan Savage
WV
I'd like to have the engine if it runs well but you're a little far from me . How many miles are a lot ?
Ya and some photos of the KJ should be a necessity! :icon_rolleyes:
RobKlinky
Detroit
I could use the connector that plugs into the cooling fan with about 6" of wire. But only if it's the 3-pin kind.
JasonJ
Michigan
Two months later and no replies, not sure we'll be seeing a response from the OP,Rob.
