IPOD Adapter with 6-disc
RenegadeBullitt
Willow Spring, NC
Do they make an IPOD or AUX adapter kit that will even work with the in dash 6 disc CD changer that is in my 06 Renegade. I am sure that question has been asked 1,000,000 times but I cant find a straight answer. I went to crutchfield.com and input all my info and a USA Spec unit showed up for my jeep but then it says it will not work on cars with in dash cd changers...I am confused. Help would be awesome =) The head unit says RBQ on it if that helps.
Yomomma7826
Kapolei, Hawaii
Sounds like you don't have the cassette slot, try and go to where all the cords are sold and buy something like this, http://www.belkin.com/IWCatProductPage.process?Product_Id=525858 What it does is, you plug your iPod/Auxiliary into it, and then you select the station you would like for it to emit, and then you tune your radio to that. Just make sure if you buy this one, if you turn your iPod all the way up when you plug it in, it'll get all static-like, so put it about 3/4 the way up on your iPod, then turn your radio up as high as you see fit :) Or you can find one, that plugs directly into your iPod charging place (the connector part), and you don't have to worry about volume on the iPod, and that can charge your iPod if you find a compatible one.
Btw: It makes use of a "cigarette lighter" port in your car.
-Chad :D
Hope I helped.
