My first post here so take it easy if this has been covered, but I was unable to find anything that helps me.
I have an 03 Liberty Limited 4X4 3.7L Automatic that is out of warranty and has just started to have the dome lights come on and off while the vehicle is sitting in my garage with the vehicle off. I have read that this could be a symptom of the BCM going bad so had the dealer do the 49.99 diagnostics on it and they didn't find anything conclusive. The multi-function switch on the column checked out fine also, which I new had TSB for a failure. All the door jamb switches check out also.
I disconnected the positive side of the battery over night, because the lights drained it the night before and when I put the terminal wire back on the lights were off, so I waited awhile and still no lights. I thought maybe it reset the BCM and cured the problem. I then opened the door and the interior lights came on, so I closed it and waited. The lights started the same sequence of coming on fading off then back on again.
Anybody ever replace one for the above problems, and if so did you do the work yourself or did the dealer do it for you. I would like to do it myself but I can't find where it is located in the vehicle without a good schematic. Beside the dealer told me it would be 405.00 for it and it didn't cover the labor. I can buy it online for a little over 300 so it would save me a bundle to do it myself.
