Interested in ome 927's
Discussion in 'Lift Kit Discussion' started by LibRenegade05, May 13, 2019.
  1. LibRenegade05
    LibRenegade05 New Member
    21
    May 13, 2019
    I'm having issues with the junk I lifted the front of my 05 renegade with sagging literally before my eyes, what should be about 2.5 inches of lift is 1.5 actual. I want to take it out and it seems the old man emu 2927 coils are the way to go. I was just wondering if anyone with these could tell me the actual lift these springs have given them and how they are holding up over time as per lift height?
    Thank you.
  2. first&lastKJ
    first&lastKJ Full Access Member
    1,155
    65
    Oct 23, 2010
    Indiana
    I just put on OME 927's, bilstein shocks and 1/4 inch top plate on the front of my wifes 02. From the center of the wheel to the bottom of the fender flare is 21.5 inches. Rear is OME 948's plus one extra upper spring isolator. Rear is about 21.75 inches.
    What kind of junk did you lift your kj with?
  3. LibRenegade05
    21
    May 13, 2019
    Id rather not say..cough daystar cough...lol so the coils gave you a 2 inch lift? Needed the top plate for the extra half inch? Im good with that as long as that's the true lift and it hold up over time.
  4. first&lastKJ
    1,155
    65
    Oct 23, 2010
    Indiana
    Yes, some get a little more lift using this same combo but this is where the 02 ended up at. OME is the way to go and hold up well.
  5. LibRenegade05
    21
    May 13, 2019
    Its the spring rate to these that give you the actual lift correct? Your bilstein's would technically be the same length as oem shocks not extended in any way?
  6. first&lastKJ
    1,155
    65
    Oct 23, 2010
    Indiana
    Correct, all front shocks are the same length.
  7. LibRenegade05
    21
    May 13, 2019
    So do the lesser duty such as medium give you less lift if installed?
  8. first&lastKJ
    1,155
    65
    Oct 23, 2010
    Indiana
    Not sure about that. I know there is alot of good info in the kj lift pics and spec thread section. We are in the KK lift discussion.
  9. LibRenegade05
    21
    May 13, 2019
    Oh really haha my bad, thank you for the information you provided me with tho!
  10. first&lastKJ
    1,155
    65
    Oct 23, 2010
    Indiana
    Your welcome, tommudd is the expert when it comes to knowledge about lifting kj's. I've learned it all from him.
  11. tommudd
    tommudd Moderator Staff Member Moderator
    18,467
    634
    OME 927s will give you 2.5 inches of lift and are rated at 400 lb
    OME 926s will give you about 1.75- 2 inches and are rated at 375 lbs
    OME 925s will give you about an inch and are rated at 350 lbs
    stock is rated at 310 lbs
    Either bilstein or OME shock with Bilsteins a bit cheaper
    plus Teraflex front bumpstops
    JasonJ likes this.
  12. LibRenegade05
    21
    May 13, 2019
    Awesome thanks tom, I've noticed in some other threads you have mentioned you have ran the 927s for a significant distance, how much height did you find you lost over time?
  13. tommudd
    18,467
    634
    My first lift on the 04 ( bought it new, lifted at less than 20,000 miles ) was 927 front springs, ran that lift until right at 120,000 miles and sold it to a friend of mine who started with a Daystar. I mounted the ARB front bumper on the front about a 1000 miles after installing the lift.
    In that amount of time ( 100,000 miles ) I lost LESS than 1/2 inch and that is with the extra weight of the ARB hanging on there
  14. LibRenegade05
    21
    May 13, 2019
    Wow that is impressive you have sold me on OME. Thank you for the info bud I realize you have to answer to these coil spring questions far too much and I didn't even post it in the right section lol. I appreciate it. The only downer is I live in Canada so no JBA parts for me cause they couldn't tell me if there was any duty or border fees on their products. I've found two performance parts sources so far that carry them in Canada.
    tommudd likes this.
  15. tommudd
    18,467
    634
    No problem at all, enjoy it.
  16. novascotiajeep
    novascotiajeep New Member
    Jul 17, 2019
    Which part stores
  17. LibRenegade05
    21
    May 13, 2019
    I got mine from tdotpreformance and tommudd was right its the way to go.
  18. novascotiajeep
    Jul 17, 2019
    Toronto then eh? They ship obviously eh? is there a link or a chat I can get forwarded to for everything I need and need to do to run a 3 " OEM lift to a factory... 02 liberty sport.
  19. LibRenegade05
    21
    May 13, 2019
    Yea they ship just goggle tdotpreformance it was free to ship for me and I'm in between where you are and Toronto...if you want 3" go with either the ome coils and a top plate or ome and a clevis I did the coils and clevis and got 3" after settling
  20. novascotiajeep
    Jul 17, 2019
    Very nice.. what's a ball park cost...
