Install dome light over rear seats?
Akedos
Elmira, NY
I know some people have talked about it and I thought I saw a thread once but searching has led me no where. Has anyone installed the extra dome light over their passengers seats after doing an EVIC install? How did you attach it to the roof? I was thinking magnets. Any other tips?
Akedos
Elmira, NY
Lol, but what if I want to change the bulbs. The bulbs are only replaceable from the back side if I remember right. If I glue it up there I can never remove it. That's why I was thinking magnets. But was wondering how others had done it too.
Circling The Drain
Just a thought, but a hard-wired LED light would pretty much reduce any maintenance.
Who said glue?
Akedos
Elmira, NY
I actually thought about switching all the bulbs to LED... except one to provide resistence for the BCM and make sure they don't glow.
Now that is an insightful post! Is it possible for you to post without coming across as a jerk?
What else do you want, its very simple to do, good golly its not brain surgery , little common sense is all it takes. No one needs to hold your hand to install a light in the roof of any vehicle, a light, wires done
How is that coming across as a jerk?
If you have something to say, PM me!:33:
CzarKJ
Townsend, MA
I'm working with that right now. I'm going to order some with built in resistors. The rear one I changed and glows so little I cannot notice it. The front two I purchased were like spotlights while driving.
Akedos
Elmira, NY
Once you find bulbs that don't glow send me a PM with a link. Save me the trouble :D
flair1111
usa
could you glue a magnet to the back of the light housing and let it stick to the metal above?
jeeptorino68
Oregon
i will play nice...only because it is in my bookmarks of things to do. have some of the parts. the bulbs are not changed from above, you can drop the lens cover down and it hinges.
the lights can also be had from durangos, grand cherokees, and other mopar vehicles
tlrtucker
Denver
pm sent mr moderator!
teckman02
trotwood ohio
It is easy this is how I did it in my 06
Just tap into the dome light wiring simple the light is clips to the headliner and yes you will need to make the hole a little. Bigger
Akedos
Elmira, NY
But I don't have a light over the rear seat like that... not even a little one to make a "bigger hole". That's why I wondered how other people attached theirs. I can't imagine there are going to be clips just waiting in the roof for me to attach the light to. The only lights I have are the one attached the the EVIC and the one way back by the gate. The one you have right their behind your cross member would be the perfect placement and it looks to me like there is something under the headliner holding it to the roof. Mine has no such thing.
Luke
Interloper
Bancroft, Canada
With the correct sized hole cut.... the fixture will clip onto the headliner... not the roof. Hope that helps you out of your quandary :D
Akedos
Elmira, NY
Yes indeed that is the info I'm looking for. Sounds a bit scary actually, but I think I'm up for it. I am also still considering magnets, lol.
