Info requested on wheels
mtbskierkj
new york
I have a 2007 Liberty, will 16 x 8 inch with a back space fo 4.25 fit without a lift and any rubbing?
and what about a 16 x 7 inch rim with a back space of 4.
I want the rims to stick out a little for a more agressive look without having to lift it. I want to put black Pro Comp Steel wheels on.
Any help would be greatly appreciated...
Thanks...
You will have major run with the 8" rims.You maybe okay with the 7" rim with stock tires only,anything bigger then then stock you will have rubbing.
The OEM rims are 16x7 with 5.5" of backspacing.
