AJ
Recently, while using both 4 high and 4 low (Command trak) the indicator light in the dash has "slipped" or something now indicating that I'm in "part-time" when I'm in 2 whell high.
The light seems to be off one detent as it indicates Neutral (really 4 high) and 4 low (really neutral).
Question is:
Is the switch for the indicater on the transfer cast shift mechanism or then where?
I'm hoefull that it's not an electronic issue but rather just a switch that has moved a little.
Anyone else have this issue, and if so, what fix did you use?
Thanks
AJ
Question is:
Thanks
AJ
