HOW TO: Install front D-Rings
LibertyFever
New Brunswick, Canada
I like what you've done, very ingenious.
I am concerned about the safety and quality of $1 "Power Fist" tow points. May I suggest you use grade 8 bolts & practice safe tugging & winching. Nothing ruins your day like a broken tow point flying through the air.
While on the topic of front tow points, I like the idea of brush bars on a Liberty but I don't like losing the tow points. Has anybody tried putting shackles on a brush bar?
I'd like to see more pics and details on your ride Gris. Get some trail lamps on that roof rack will ya, three or four Hella's would be sweet.
Oh, one last thing. I imagine if you don't have a "REALLY big drill press and lots of cutting oil/time" you could always take it to a local machine shop that does.
Gris
Scranton, PA
LibertyFever, look closely under the front of the rack, between the roof and the rack itself.
Also, a link in my sig goes to a web page with lots of details. A couple of the "Action & Adventure" pages show me towing, or being towed, with the shackles.
fouros
Gold Coast Australia
liberty fever if you purchase a TJM T16 grille guard the mounting brackets come with revovery points that you can install RATED SHACKLES on, the only thing i would reccomend is a equalizer strap between the to recovery points and a good quality snatch strap ( like a big bungee cord) not much momentum to unstuck a vehical, i have been recovered with my t16 and its all good
KJ2005
Las Vegas
where to purchase D-rings?
where can you purchase D-rings? Pepboys? Home Depot? Walmart?
JeepINgeek
Silver Supporter
For Twain In Diana
Gris, can you give details on your install? I have an 06 and when i was looking at my subframe on the front i noticed that if i were to mount flush to the frame i would have to cut my fascia along the top. it appears in your image that you didnt have to. Did you use a spacer?
candpliberty
Las Vegas, Nevada
I looked all over for a front hitch but no one seems to make one any more.
Reese use to make one but no more part number.
Atrus
Metro Detroit, MI
SDLiberty
Oceanside, CA
Bennett, Loved the idea and had to do it. Followed the instructions but added a 1/2 plate between hitch and frame.
1/2 in. plate between the two
Used a drimmel to cut holes, recievers will then slide right in. Nice and tight!!
Finished product W/O D rings. Used 7/8 step bit to open up holes for the use of 3/4 D Rings.
I just realized how long ago Gris and Bennett did these.......#-o:D
SDLiberty
Oceanside, CA
Still no D Rings:( but here is finished look
NewJeepOwner
Ohio
Dead pics suck but I think I can figure this out with what you've provided ..Is it absolutely necessary to remove the front bumper though?
SDLiberty
Oceanside, CA
Yeah unfortunately. Once bumper is removed there will be a black cap that covers this access hole. This is where the bolts will go through and need to attach washers and nuts to fasten it together. Seems like a big job but gets you familiar with the front end. http://www.jeepkj.com/forum/showthread.php?t=25620
Prospect62
New Hartford, NY
What size holes need to be drilled into the arms to mount them to the frame and how far apart do you space them (the holes)? Has anybody measured that? What size bolts are used?
I'd like to do this but I'm going to have to have a machine shop do the drilling for me as I don't have anything that heavy duty in my garage...would like to have all the specs so I can go buy the arms and bring them to get drilled before I take my front end apart.
***EDIT - Never mind, found it on LOST.***
Prospect62
New Hartford, NY
Here's a picture of my finished product...did it almost a month ago.
