HOW TO: Find a How-To not listed here & Forum Guidelines
new jeep owner
New Brunswick Canada
front wheel bearing
has any one changed a front wheel bearing yet? is there an inner and an outer or is there just one? I think mine is getting bad on the drivers side .
any help is appreciated. I have an 06 sport .
dirt pig
AUSTRALIA
Silly question, but can't seem to find a "How to clean the Maf sensor".
I'm trying to locate the MAF sensor on an 06 3.7 Liberty (So I can Give it a clean),
Removed what I thought would be the sensor but appears to activate some sort of butterfly valve in the inlet.
Country_rob
Woodland Park, CO
Mopar Transmission Skid Plate
Howdy,
I'd like to see a step-by-step installation of converting the 2005+ OEM Mopar transmission skid plate for a GAsser to a 2002 - 2004 KJ Gasser. I've read some discussion regarding this but some said it can be done easily by drilling a hole or two, and others have said that the transmission skid for a 2005+ is too short for a 2002 - 2004 KJ. Does anyone have any real experience?
My transmission is a 5-speed manual with Select-trac transfer case, if that makes any difference!!
Please help!!!
Rob K.
BIGE15
Denver
Are there any threads on performing you own alignment before or after adding a lift kit?
K7AAY
Portland OR USA
Replacing factory fog lamps w/ brighter in 06 Ltd CRD?
How might I go about replacing the factory in-bumper fog lamps in my 2006 Limited CRD? What choices do I have to improve on them? How 'bout dem Mudhens?
Chillbilly
Maryville, TN
How do I remove dash panel?
I need to remove the small panel in the dash to the left of the steering wheel. It vibrates causing an annoying noise. I want to insulate it to stop the noise. Anyone know how to remove it? I should mention that this is on a 2005 Liberty.
viperpit07
wisconsin
i would like to know if there is a mod so that my fog lights stay on when i turn on my high beams, not just when the low beams are on. thanks
drjones
indiana
aluminum radiator
had to replace the original radiator and now this ones leaking
have read that some people have replaced theres with an aftermarket or custom aluminum unit but found no details
is there a wright up on this or anywhere i can find specific info
Larket
norway
Seatbelts
how to change the seatbelt on the driver side of the libby 05, can i change only the belt or do i need to change all of it?? pics??
alberni83
bc
stock fender flare trimming info and pics
looking to see what anyones done for trimming 2002 kj flares.
any pictures or info maybe links to see what i want to do to mine.
thanks for any help.
i have searched and havent come up with much ,i am not sure if maybe it isnt a common mod
kevin mn
Illinois
any pictures anywhere to remove and replace the power lock switches on the front driver and passenger doors? The little LED's no longer function. Not a big deal but if I find the moment, this might be a weekend job I'll undertake. Already have to replace the center A/C, Heater unit as it no longer lights up when headlights are on at night.
baer jeeper
winnipeg,Manitoba, Canada
i'm wondering if anyone has an easy way to access the harness plug/connector for the bank 1 sensor 1 o2/oxygen sensor on at 2006 (June 2006 build date) the connector is tucked way up on the back of the engine and i can not get my hands up that far to get it apart,
TheZombieNinja3
Ellenville New York
Snail Farmer
Fairmont, MN
It's held up well for me. I use it every day in a machine shop and it hasn't failed or broken yet. But you can't plug a different 3.5mm jack into it as you can see from the pictures here.
