Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have read several post on how to read the check engine light I have that down but How do you clear it after you fix the issue and it will not go out.
I had the check engine light for a loose gas cap. After about 6 run cycles, I disconnected the battery's negative cable for 60 seconds and that did the trick for me.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
