How do you get a 4 inch lift??
UAE Jeep
Dubai
how do you acheive a 4 inch lift on your KJ? what do you need to do
With JBA's 4 inch lift kit at $3,049 plus shipping.( You would also require shaved CV's)
http://jeepinbyal.com/prod-4_inch_lift_kit_Jeep_Liberty__KJ__2002_2007-694.aspx
The adjust a struts are expensive in the 4" kit.
That is why most (including me) purchased the 1.5 lift (927-948 springs)with top plate & 3/8 upper steel spacers, clevis and JBA 4.5 A-arms, & rear isolators for half that price as above and you get about 3 inches.
http://jeepinbyal.com/prod-OME_1_50__lift_kit-634.aspx
Like Ryan, I say the Frankie is also the way to go, pre-assembled ready to drop in, and u get top plate and order separately the JBA4.5 A-arms and Boiler's 3/8 steel spacers, Teraflex Stops & rear Isolators.
http://www.boulderbars.com/frankenlift.htm
My front hub to flare is 22.75 inches. Just under the 23 " inches is where you want to be, as when you go over the 23" you will also need to get the shaved CV shafts $$$! as well.
40586[/ATTACH]"]
Jeep's are built! They don't come this way!
Red_KJ_666
Riverview NB Canada
Ya, a Frankenlift along with a clevis lift, 4 extra rear spring isolaters (Buy some machined down CV joints) and you too can have a four inch lift.
It's easier/cheaper than that, but not worth it as you don't gain ground clearance.. Franky or OME/Rancho Clevis lift and dropped cradle, out back move the shock mounts up and add Iso's
Actually by doing a cradle drop(which more headache then it's worth) reduces the front ground clearance so no gain from adding larger tires this way.
