How about a set of these when you do an SFA!
J-Thompson
just south of doucheville
I'm surprised that nobody replied to this!
Must be to good or expensive!
I would say price may be an issue
>Portal Axles Generation III Quote
Every standard axle setup will include the following:
Wilwood disc brakes (heavy duty vented rotor, caliper, and pads)
Drive plate or manual locking hub assembly
Loaded Portal-Tek portal boxes
4340 axle shafts custom built CV Shafts
Custom width SpiderTrax 3 1/2" housings
Center section (Ring and pinon gears, bearings and seals)
F-450 Unit Bearing
High mount steering setup
Standard Axle Pricing: MSRP-- Front Axle : $8,499 <---
Rear Axle: $6,999
Standard axle setups will include the following options:
4340 axle and stub shafts
340 CV Shaft or U-Joint Option
4 Piston Wilwood brakes
F-450 Unit Bearing
Rear Axle: $6,999
With that kind of hardware(mainly the F450 unit bearings) your stuck with using 19" rims or having custom wheels made.Oh and not to mention you'd have to do alot of custom modifing to the drivetrain since you'd need to make the drivetrain spin backwards from it current way of rotation to run portals.
If you want Portal's the way to go is the Volvo Portal's.
It's from December of 08...he changed in Feb or March of 09...
Inc
Free
I have a friend that wants to put those under her jeep.
