Horn question
hyde
I see that Jeep has two horns, If I just buy a single air horn, should I just tape the old wires for the 2nd or can I actually wire two air horns, is there enough current for two?
If I remember right each side of the stock horn has separate wires going to it.
As long as you have a good ground, the positive should attach easily to one or both extra horns mounted up front etc.
As far as the juice goes..you should be fine, you have two stock horns. As long as you are removing the stock wires from both and extending those wires, you should be good to go.
hyde
I won't have to wire since wolo is a direct replacement, so I just snip & wire on existing wires. Double Dual horns would be sweet, but one of the stock horn is very weak (I am guessing lower power), has anyone tried removing the harness of one of the horns, the other one is like a rat with its tail stuck... meeeeeek! :)
The stock horn I think have a steel bracket riveted in. The location of them leaves mush to be desired.
I would extend the wires and move the Bad Boy more forward like somewhere around the front or behind grille.
That would make the sound more forward projecting.
