Hitch lbs
rchung813
New York
Just a curious question, how much does the MOPAR hitch receiver wieight? This is for part #82207535. I just received my hitch today and it seens solid and has a good amount of weight.
tgh117
Emmaus, PA
If I recall when I installed mine, it wasn't overly heavy. Maybe in the neighborhood of 30-35 lbs. Real easy to install. Good luck
rchung813
New York
Yeah it looks like it would be easy, just 6 bolts to tighten. I'm wondering since there are no nuts, wouldn't the bolts loosen very easily?
tgh117
Emmaus, PA
No, there are nuts welded from the inside of the frame rail, or clips I can't remember. But they are plenty tough, I am not worried about it comin loose.
rchung813
New York
I just installed my hitch, sort of, I was able to screw in 5 of the 6 bolts. I wasn't able to screw in the 6th bolt because of muffler pipe was in my way. Is there anyway around this?
JC
Arnold MO
I have the same problem, but compounded by the fact the nuts in the frame were rusted badly, and on the one you're describing I can't get tap into it. Also the slot in the hitch does not line up properly. I'm wondering how safe the hitch is with 5 bolts? I'm not going to be hauling a trailer, but rather use it for a cargo carrier and/or bike rack, and if need be for recovery with a D ring?
SRotblat
LOST #666
I recall the 6th being a huge pain in the rear on mine I had to single handed push the exhaust a bit to the side...does not more much...and couldn't use my socket set. was a while ago but I think I ended up using a wrench with a breaker bar.
