Help
nick25crd
Thessaloniki,Greece
My 2.5 crd isn't strong anymore.it can't accelerate as it could and can't reach even more 2800 rpm with the 5th gear (it is manual).
What could be?it isn't problem with the hoses.
bugnout
Illinois
Are you seeing the Check Engine Light CEL? Can you pull codes from the ECM? That would help to diagnose the problem.
goatkj
Sacramento, CA
I'll bet journeymanjim is right. For my own, it started fine one morning, idled fine, but was absolutely gutless when I drove (to the point of being dangerous on the road!!!). Turned out to be a pinched vacuum line to the turbocharger.
flman
jyjhbkbu
DOES ANYONE KNOW IF CODE:p0846 2/4 Pressure Switch Sense Circuit (41TE, 42LE) CAN
LEAD OUR CRDS IN LIMP-MODE(SAFE-MODE)
Being the ****** is a vital part of the drive train, I would not be surprised if it can put you in LHM?
