I did a auto transmission and filter change and as soon as I was done I started her up and tried going into the gears but it wouldn't. I was able to shift the lever but there is nothing going on down there. I know there is the right amount of fluid. Could it be because I took out so much fluid that there is not enough inside the transmission? Cause I defineately got out more than 5 quarts.
