Help me figure out where this wire goes
yippee
Texas
05 Limited 3.7 Auto. The wire is on the passenger side, under the hood, back by the cowl. I'm assuming the wire is a ground? Anyways, I'm just wanting to figure out the correct spot for it so I can get it hooked back up. Thanks.
JeepinJarhead03
Petersburg VA
it goes right there about 2 inches to the "north west" of where it is at this moment, its supposed to be under the head of the bolt there in the picture that has dirt rubbed off of the top edge of it as if its been recently removed and someone forgot to put the ground wire back ;)
yippee
Texas
Perfect, That's what I assumed. But I just wanted to make sure where it was supposed to go before I put it back. I know as long as it makes good contact a ground should be a ground, but I wanted to put it back where it was supposed to go. Just another follow up question, do you know what that is a ground for? Just curious what hasn't been grounded. Thanks for the confirmation and help!
Logan Savage
WV
My 05 has a ground wire like that , in that area ,that goes up to the hood . my 02 does also , don't know why because there's nothing electrical on the hoods .
