Help, A/C clutch cycling on and off
whkdad
NY
Went for a quiet ride today and heard an odd low pitch cycling clicking sound. Popped the hood and saw that the A/C clutch was cycling on and off with the A/C switch off, turned on the A/C switch and the clutch still cycled on and off. I know on my other vehicles, if the A/C is on the clutch stays engaged and the fans are running on high. Is this normal for a '06 3.7L stock Liberty? Any thoughts before digging into the wiring schematics.
Billwill
White River, South Africa
The AC is supposed to switch on/off even when the AC is not turned ON.
I have seen some posts where owners have overiden this feature but it is supposed to be normal....to prevent screen frosting up I believe.
With the AC On I believe the clutch still does cycle a bit....I think to stop the condensor from icing up. Have a look at what your Service Manual has to say!
Porkchop
Troy Mi
A/C is the dehumidifier also and to cycle is normal to an extent.
CzarKJ
Townsend, MA
With mine it was on and off quick. Turns out I was low on refrigerant. After I did a quick fill with one of those do it yourself bottles it went back to regular cycling.
