Heater core
ktmrider
Northwest MS
Can the heater core leak and not fill the floorboard? I have a persistent coolant leak that I can't find and the heat is weak and nonexistent at idle.
RenKJ
Canada
How are engine temps? Have you checked the seal around the water pump?
ktmrider
Northwest MS
Temps are normal, as long as the right amount of coolant is in the system. Water pump was replaced about a year ago, radiator this summer. I'm running out of options. Believe me I desperately want it to anything but the core.
Chitownjohnny
Chicago
The upper left side of the radiator is prone to leaking the driver side top if your looking at it from the front. Check it under running temp and see if you smell something or see something.
jeeptorino68
Oregon
im diving in to replace the heater core.
coolant drips out of the drain tube from the heaterbox (normally just for condensation from the AC
any other tips or things to look for or replace while i am in there?
