Harsh Shift or Tie-up When Cold
eilish
Canada
When I start the jeep, it would jolt when driving it, but it seemed only until the engine would warm up, then it seemingly would run fine.​
To date I have tried everything including changing the transmission to no avail. Everything I have tried is here:
The vehicle Harsh Shift or Tie-up When Cold
*DTC PO868 Line Pressure Low
*PO 934 Line Pressure Sensor Circuit Low
-Removed Pan Replace Filter
-Check SVolt Ref Circuit
-Check Line Pressure Signal Circuit
-Replace Transmission with used unit
-Replace Filter in Transmission
-Perform Transmission Relearn at Dealer
*Still have PO868 Line Pressure Low***
I am wondering if I need a new computer for the vehicle, if that is what the problem is, and how much one of those costs? Are they available used?
ftaa
canada
sounds like an electrical pigtail .. shorting the sensor.
