Good scanner
eric1514
ID, USA
Hi,
I found a good, inexpensive scanner that works with my old 2003 KJ.
It's an XTOOL A30M V2.0.
Does it see the TPMS? I'd love to turn off the light on my dash.
Also, I have the Ediag Elite and it does not see my 2005 KJ.
u2slow
BC
I have been able to get every error code with 3 cycles of the ignition. No scanner needed. Thanks Mopar!
Geralt
FR
I don't know, because I don't have TPMS on my 2003 model,
but the app has a lot of features, and updates are free.
Geralt
FR
It's good for u.
I have just one fault code, P0070, indicating a fault in the ambient air temperature sensor circuit; I clear it, but it comes back.
I need to replace that sensor.
u2slow
BC
I've had lots of faults. Usually they go away after checking, or go away on their own later. Or disconnect the battery for a bit to start fresh.
Cruise and the 'gas-cap' codes are common for me.
eric1514
ID, USA
It's good for u.
Maybe. Check the wiring and connections to it first.
Geralt
FR
Yes, I should if that's okay, I'll replace the temperature sensor.
Thanks
u2slow
BC
Its not very often. But between opening the gas cap now and then, and fillups, the light goes away again.
Voorstedt
For about a year, swapping gas caps between the original and the one from my 01 cherokee, AND the new (non OEM) one I bought made the light and tone go away without even a brain wipe. Just a few starts. Stopped working a few months back. Got used to the permanent engine light, (just a little vap leak) cause it is quiet. GASCAP makes a noise, and flashes. PINHEADS. Fun little truck anyway!
u2slow
BC
AFAIK, the venting is supposed to happen through the evap system. Not direct to atmosphere.
I typically hear air rushing past the cap on loosening. Not sure if pressure or suction.
Bottom line is I dont care enough to chase an occasional engine light. Keep on truckin.
