Both driverside parking lights are out, being that its both I dont suspect its a bulb (can cant find my torx bits to remove the lenses to confirm it) so I was checking the fuses. Turns out there is one fuse for each side parking light.
According to the user's manual
pin 9 is a 10amp for Right Park Lt/Right Tail Lt/Trailer Tow Lt/Cluster
pin 23 is a 10amp for Left Park Lt/Left Tail Lt
so I check pin 23 and find NO fuse....sticking pin 9's 10amp in to test makes it feel that there is no contacts behind the pin 23 openings....
Anyone have an idea where the fuse for the Left Park/Tail is?? doesnt seem its labled correctly in the owners manual ](*,)
