Fuel gauge never goes down, needle stuck in the middle
estebanrf
mexico
I have a Liberty 2007 4x2 Limited and the fuel gauge acts strange, never show levels below half tank, is stuck in the middle, but at filling up the needle starts moving up and upon the end shows a check engine error code about an "implausible fuel level" or something like that. Send the car to the dealer and replaced the floater sending unit but the problem was not fixed. What could be the problem???
TwoBobsKJ
Northern Ohio
Well, I would say the problem is the dealer - they replaced a part without fixing the issue. Take it back and tell them to fix it right this time.
ThunderbirdJunkie
Bronze Supporter
Newport, KY
ThunderbirdJunkie sees no problem, you'll never run out of gas!
The sending unit is dead or the wiring leading from it is compromised, check wiring first.
Also, the only reason you're having this problem is because you called it a car :)
clauserg
Hello... Hope somebody can read this messaje... I have the exact same problem with my KJ 4x2 2006... I would like to know how the issue with the harness was fixed or was it fixed by the dealer without not telling you what they did??
Post number 4
Problem solved. It was a bad connection in the harness coming from the fuel pump/sending unit.
so more than likely they just started checking all wiring/ connections etc and found it
clauserg
Thanks... I just wish to know what wiring was checked out so that I can try to fixt it myself
Just hangin' out.
Post number 4
Technique known as “Easter egging” by us twidgets…tried and true…
clauserg
Is there a way to find the wire harness diagram and the ECU connectors pinout for this Jeep KJ 2006?? (FREE)
Just hangin' out.
Yep. Just search the forums here for 2006 parts fiche and service manual. I’m on mobile or I’d post a direct link
