Frt Differential Drain, '02 Liberty
LibOhToo
U.P. Michigan
I don't know much about anything so here goes.
Went to drain my front differential the other day but could not find the drain plug. The fill plug in plain view.
Do I need to remove the skid plate to get access to the plug?
Thanks
Yes, the drain plug is at the bottom of the diff. 8mm allen key IIRC.
JasonJ
Michigan
It's so easy, once you see it... you'll wonder and wish and kick yourself for not doing it more often.
Although I found after the fact that a pump attachment for the lube bottle would make this 10x simpler as well.. just stick hose in and pump to refill, no finaggling to try and fit the lube bottle sideways to fill.
