Front trim spacer -- ?? -- how to ??
Fjellfinn
I just bought a nice Rockrail from rocky-road.com, and one pair of
"front trim spacer"
I have a 2003 Liberty (cherokee in Europ) which I am now to put in a standard OME 2" lift (4 coils, 4 shocks)
Where do I put these front trim spacers?
And what will they affect my standard 2" lift ?
steepcreekfreak
Kent, Ohio
If you have the OME you can use conduit lock nut or the spacer. Here is a link that shows you where the spacer goes. It compensates for front end sag in the lift due to the extra weight of the egine and stuff. I don't know if the spacer or the nuts are better. The nuts give you more adjustablity though.
I used three conduit nuts instead of a spacer though on mine. Works great.
http://www.jeepkj.com/forums/viewtopic.php?t=6814
KJ04
Grafton, Ohio
"front trim spacer"
Not for sure but, since the front OME Medium coils only give you 1.5" they may be small strut spacers that sit on top of the front strut. Perhaps the 3/8" spacer that goes with the RRO 2.125" combo kit to boost you to 2 ''.
