AlexKJ
Hi... searching the Web I found a couple of things, that can be summarized in this 2 posts
Have this any relation with the diff case that Marlin sells?
Cheers!
http://www.jeepmilitia.com/forum/f12/off-road-pictures-badlands-208/index3.html said:The KK's (2008+ Liberty's) are even more capable than the KJ's they replaced. Same strong 3.7l engine, 42RLE transmission (as used by pretty much every auto Jeep out there), NP231 T-case, 8.25 29 spline rear axle, and an (improved over the KJ) Dana 30M front axle. The front axle has more gearing options, and can handle up to 33" tires with a 2.5" lift. There's at least one or two companies making rockrails and other armor for the KK's too IIRC.
anything that fit a JK dana30 will fit the KK as far as gear and lockers. I curently have a jk diff housing with a driver side bent tube that I got for 20$. I will modify it to bolt on my KK![]()
Cheers!
