Fall KJ Inspection
Well I got 45 min on a lift on Monday. All fluids/lube, oil should be good.
Here is what's on my list:
Look for rust- spray paint touch up.
Silicone spray to cv boots, look for cracks, no grease flings please!
Rear brake star adjusters spin em, adjust properly again.
Check tri-link look at bushings/upper ball joint.
Look for leaks in driveline, pinion, main output shaft, oil & trans pan, front & rear diff/cases. Check levels.
Look for any engine oil leaks upwards towards valve covers etc.
Check/inspect U-joint, not to be hot, (no current clunks)
Spin tires forward (may make a video) showing tire rotation with Trac-Lok, check level in diff. Wheel bearing checks. Check tires for nails etc..
Brake pads to be even & percentage left & rotor runout check. Brake fluid test strip.
Lube upper JBA 4.5's.
Exhaust inspect/should I tap on the cats or leave em alone?
What else am I missing? :shrug:
M38 Bob
Arkansas
Doesn't take much of a tap on cats to hear loose media. I usually use the palm of my hand.
M38 Bob
Arkansas
You are referring to the catalytic converter right.
Not judging otherwise, you can do what you want with your own cats! :happy175:
Last two tomcats, I neutered in a 5 gallon bucket. One of em still looks at me with distrust, and hatred.:icon_twisted:
I guess you could wait for winter but silicone spray the door weather stripping?
lube hinges, etc maybe?
