Exhaust Gaskets
J33Pfan
NY
Hey all!
2002 v6 4wd limited
Is there a gasket between the passenger side/Bank 2 connection between the exhaust manifold and the cat?
I didnt want to over tighten the V clamp and now I have a leak with no gasket before & after removal.
Could it be the V clamp is worn or not tight enough. I'm not use to not needing a gasket.
Also, there are so many exhaust gaskets listed on Rockauto.com. The Y pipe to the bank 2 is a Large walker 61289, Is the Bank 1/Drivers side the same one?
thanks in advance
Hey all!
2002 v6 4wd limited
thanks in advance
Not sure about the Y pipe gasket but I would think they'd be the same. There is no gasket where the V clamp goes. Sort of a ball in socket connection. I believe the V clamps are considered not reusable but I reused mine a few times.
