esp and abs gone crazy after lifting
pmarcotulli
Caracas, Venezuela
hi, last week i lifted mi 06 kj renegade 1" using spacers. since then the esp and abs are dis-controlled, when braking or turning the esp and abs lights start shining and then stay on for a while. then the process start over again... please help...!
pmarcotulli
Caracas, Venezuela
i did get an alignment, make a computer reset, disconnected the battery and connect it again. with the lift i had to change the housing of the front bearings, they came with all the sensors and wiring, so that is all new. i dont know where´s the origin of the problem.
pmarcotulli
Caracas, Venezuela
i connect the computer myself and get this code: C1027: left rear wheel speed sensor erratic performance. im working on it, ill see if its disconnected or displaced. thanks for your help!
