esp and abs gone crazy after lifting
pmarcotulli
Caracas, Venezuela
hi, last week i lifted mi 06 kj renegade 1" using spacers. since then the esp and abs are dis-controlled, when braking or turning the esp and abs lights start shining and then stay on for a while. then the process start over again... please help...!
rockymountain
Spencerville, IN
Make sure you didn't pull out any of the wires that go to the sensors in the hubs. Make sure all the electrical plugs are plugged in and that the wires all look good. What all did you do for the lift? more info will help you.
rockymountain
Spencerville, IN
Also, did you get it aligned? That may mess it up too. You must get an alignment if you change height in the front.
pmarcotulli
Caracas, Venezuela
yes, i did get an alignment, make a computer reset, disconnected the battery and connect it again. with the lift i had to change the housing of the front bearings, they came with all the sensors and wiring, so that is all new. i dont know where´s the origin of the problem.
rockymountain
Spencerville, IN
Recheck the connections.
