Engine question 3.7
rjkj2005
US
No. It will fit yes but you will have to change the relucto rings. To do this you will have to disassemble both motors
Sent from my SM-G900V using Tapatalk
rjkj2005
US
02 and 03 use the same relucto rings. 04 and up are different
DennisG
Florida
engine swap
Thanks I got an 03 with good motor and found a 04 with a bad motor
......I'll keep looking
TwoBobsKJ
Northern Ohio
YES IT WILL WORK!
The computer was changed for the '05 model year and later to the NGC version - the '02 thru '04 used the JTEC computer.
That '04 WILL work in your '03.
P.S. The two timing components that would need to be changed if you used an '05 or later are the crankshaft reluctor ring and the camshaft timing sprocket. For a complete overview of the process go here: Engine Swap Overview
