Engine Light came on today..need your opinion
thekjwith9lives
Pasadena,TX
Ok so the glorious check engine light came on today.Took it to my buddys shop and found it threw the code P0572 which is BRAKE SWITCH 1 SWITCH STUCK ON.The brake lights work fine, what else could this be? The brake switch is only 9.99 anyway but i dont know why it threw this code if they work just fine?
thekjwith9lives
Pasadena,TX
See the thing i forgot to add is that my speedo is messed up.My dad cleaned undercarriage and the speedo jacked up afterwards.It ll work sometimes but then it'll just fall to 0 and then sometimes it'll just go up and down up and down and either stay at true speed or drop to zero.Ii was on highway today and it was working so i turned on cruise control and it stayed for 5 mins until the speedo quit so cc stopped working..after that is when i noticed the check engine light came on.Sorry i forgot to include that in first post
thekjwith9lives
Pasadena,TX
the wires for the speedo?I'm not sure he said he cleaned the bottom of my jeep.I wasn't there.But he said ever since then it hasn't worked correctly.He wanted to use his new pressure washer because there was mud under my KJ.
jnaut
Seattle
"Much trouble in life comes from fixing things that are not broken." -- Welder in Baja Mexico.
thekjwith9lives
Pasadena,TX
Ok so today i went on highway and speedo was working fine.I started cruise control and was working then i pressed on brake pedal and engine light went off? crazy but apparently it fixed it
thekjwith9lives
Pasadena,TX
How not? The speedo is working perfectly fine and cruise control works perfectly fine.Brake lights and all work.There isnt anything wrong happening.It been doing just fine since last night
ptsb5a
Northern Alberta, Canada
Due you dont have to be a smarta$$
Yeah, he does. It's his shtick and I'm jealous that TBJ pulls it off so flawlessly.
Now go and check the wires/connections on the top of the diff. If the connector is loose, wires are broken/chaffed the transducer there will NOT transmit the wheel speed info to the rest of the KJ that needs it. Stoopid tone rings. Why did the manufacturers ever quit using a cable from the trans output shaft?
