Engine Coolant Temperature Sensor
nikopts
georgia
Hi
Can You help me please? Im interested in if Engine Coolant Sensor Could Turn Radiator Propeller Or not? my propeller dont works and where is its sensor can dont you know?
Thanks
renegade 04
Albany New York
Do you mean your water pump is bad? if so you need to replace it and you may want to think about replacing the engine coolant temperature sensor as well.
You'll get a code if the sensor is bad. Easy to replace, just take the alternator out and it's right there. Could do with when you do the water pump, saves a few mins since you'd have the belt off already, but it's no biggie to do on its own.
towpro
SE pa
he might mean where is the sensor that turns on the electric cooling fan.
