AlexKJ
Two transmission related questions
1.- The owner's manual states:
A) A complete flush
B) Just drain whatever pours down when you change the filter and refill to proper level
C) Other thing that I still don't get.
I know that it's desirable to change filter(s) at 30,000 mi, but I'm not asking that... It's just I found the direction a little ambiguous.
2.- What of the following 3 are correct:
A) First you change the filter(s) and then you perform a complete flush.
B) First you perform a complete flush and then you change the filter(s). You'll loss some new fluid in the process, but it's how must to be done.
C) Make no difference between A) or B)
D) None of above it's correct.
Thanks!
Ok... easy to understand the "replace main sump filter" thing... but what does it means the "Drain and refill the automatic transmission fluid" part?"Drain and refill the automatic transmission fluid, and replace main sump filter."
A) A complete flush
Thanks!
