Dome light wont turn off ....
albrandwood
ever since we got the KJ the dome light has been stuck on ... I've replaced the Multi-function stalk, but that didn't help... so I'm assuming it's probably the door sensors ... what is the best way to verify that? What are the pinouts on the dome light supposed to be? I'm assuming either one is either 12V hot and the other two are grounds in the Multi-Function switch, and the door sensors, or vice-versa ... but then again, it could be PCM controlled ...
ikuo78
Japan
In the 2003 manual, the middle is B+.
If you don't have an EVIC it can be tricky to know which door is open.
The manual says it can be diagnosed with DRB3.
I don't know if it can be diagnosed with an OBD2 scanner.
