MarkMatters
Just wondering if anyone knows the dimensions and sizes on the daystar 1.5 inch spacer for the front...
It's a 3/4" tall spacer, which gives you 1.5" of lift. Not sure if you can buy it separately, but Rusty's sells similar ones.
hm, I had no idea rustys made those. And for $20...I was going to have someone make those for me for 30...I'll just go this way then....so according to whatyou said, this .75 spacer is going to give me 1.5in or just the .75?
It should give you 1.5" of lift. Do you have any aftermarket springs installed? If so you will need Daystar upper strut mounts.
JBA sells Daystar Strut Plates:
Left: http://jeepinbyal.com/prod-Daystar_Strut_Mount_LH-583.aspx
Right: http://jeepinbyal.com/prod-Daystar_Strut_Mount_RH-582.aspx
so.....rusty's 2.5 inch coil lift....rusty's .75 in spacers....rusty's strut plates...NOW, what issues am i looking at? and what total lift am i looking at? and in your guys opinion, is this a good way to go?
So let's forget about daystar for now, with rustys .75 spacer.....is it a must to have the upper strutplates? And why?
...he just sounded creepy...
hahaha, thats pretty darn funny.
He also says that there is nothing wrong with his rear shocks.
The plate that JBA has is the daystar spacer. Im not sure what rustys has.
edit: Just looked at the rustys plates. Those are actually spacers, not upper plates.
