Dash Lights
Corwyyn
Southeast of disorder...
The FSM says if you have a inoperative lamp to replace both the lamp and the lamp holder. Me, I'd replace the bulb and call it good as long as it worked...
CLUSTER BULB
This procedure applies to each of the incandescent
cluster illumination lamp and bulb holder units.
(1) Disconnect and isolate the battery negative
cable.
(2) Remove the instrument cluster from the instrument
panel. (Refer to 8 - ELECTRICAL/INSTRUMENT
CLUSTER - REMOVAL).
(3) Turn the bulb holder counterclockwise about
sixty degrees on the cluster electronic circuit board
(Fig. 5).
(4) Pull the bulb and bulb holder unit straight
back to remove it from the bulb mounting hole in the
cluster electronic circuit board.
And as the Brits say 'installation is the reverse of this procedure' :)
the_titan
the lamps are the same as with the EVIC, they are just little bulbs mounted to a plastic disc smaller than a dime. They are not colored, the cluster is. You can change it if you want but it is complicated and you are better off just taking the cluster apart and using lighting gels from your local guitar/music store to do it. Plant one between the cluster backlighting layer and the backdrop thing...you know...whatever it is called that has the cluster printed on it.
teeje
Toledo
