CV Joint/ Boot replacement?
legending
Arizona
So i recently discovered the boot on my CV joint was bad. Just curious if this means i should just replace the boot or the whole cv joint? When i engage 4wd currently it clicks at low speeds.
Leeann
Maryland
Front driveshaft or front CV half shaft?
If front driveshaft, see above.
If front CV half shaft, go to NAPA and get a reman, not new, reman CV half shaft. Boot's torn, dirt and grit have gotten in there and done damage.
