Cooling fan install
superliberty
Fort Lauderdale
The Temperature here in florida reached triple digits this august.
I installed this 10 inch fan, that helped significantly with the a/c and radiator cooling.
I wired a fuse and a relay so the fan works only when the key is in the ON position and when the TOW switch is engaged.
I also mounted a lighted switch, RED light = fan is off, GREEN light = fan is on and running.
When the key is removed, all power to the fan stops.
Chris_22
Beaumont,tx
interesting. i dont have many problems with the ac and radiator, but its getting pretty hot in texas. i may have to try this
