My cooling fan dies not come on at or around 90 degree Celsius. I've checked the fuse and the fan motor and they're both good. I unplugged the coolant temp sensor when engine was cold and the fan would come on right when engine was started. I checked continuity on the sensor and got 2.4 kohm. After the engine running for a bit I plugged the sensor back in and the fan shut off and I got the temperature reading. When I unplugged the sensor again the fan stayed off. Could I have fooled the computer to thinking it's cold to keep the fan off? Can a temp sensor give temperature readings but not turn the fan on? Thank you. Also with engine cold I mean sitting outside in minus 20 Celsius all day.
