Coolant hose
KJGremlin
BC
So yet another issue on my 02 KJ 3.7 that I appropriately call Gremlin. To make a long story short I took it to a shop and they had diagnosed that the water pump needs replacing. So after some research I decided to pick it up and limp it home (about a 10 minute drive from the shop it was at) and as I was getting home one of the coolant lines decided to burst and dump most of the coolant onto the ground and I can’t figure out what the hose is called to buy a replacement. I will attach a picture to what I’m referring to. In the picture it’s the circled hose that burst just below the metal clamp on the right hose just behind the belt. Hope that description makes sense :]
duderz7
Weiser, ID
If I'm understanding, I believe you're looking at heater core hoses, bypass heater hoses, heater hoses. Something along those "lines"...no pun intended.
KJGremlin
BC
Thanks! It does look like that’s exactly what that hose is.
